should there be wiggle room in bushing for door pins?
Old Mar 17, 2013 | 5:28 PM
stanman's Avatar
Default should there be wiggle room in bushing for door pins?
ok so this is my second set of door pins im ready to put on.
I first wanted to check the pin and bushing fitting and noticed theres a slight wiggle. It had plastic bushings before and some were still good and fit tight but i took them out any way.
Old Mar 17, 2013 | 5:50 PM
model/year?
no, it should not wiggle.
use brass bushings not plastic
Old Mar 17, 2013 | 6:05 PM
stanman's Avatar
79 chevy c20.
when i slide the bushing over the pin and tilt it. the bushing slides up and down. also has a slight wiggle.
the old bushings fit really snug and you have to slide them by hand.
Old Mar 17, 2013 | 6:30 PM
stanman's Avatar
also the last set i tried and didnt work. the spines wouldnt hammer in to the bushing
Old Mar 18, 2013 | 8:06 AM
I don't understand. If the bushings were good and fit tight, why did you take them out? If the spines or splines wouldn't fit into the bushings, you have the wrong sizes. They are not supposed to be hammered into the bushing.
Chevrolet Forum News
May 31, 2013 12:38 PM
arctic_94
Jul 1, 2008 9:23 PM
jcw1500wt
Mar 24, 2008 11:07 PM
hardwarz
Oct 15, 2007 12:17 PM
blackmax
Jul 25, 2007 5:07 PM
