slugish motor. help!!!
Old Sep 19, 2007 | 8:34 PM
pete90's Avatar
Default slugish motor. help!!!
so the car hesitaites to start. it goes almost silent about 2 times then faster and faster till it starts. everytime that happends the lights getdimmer till it starts.then after a while of drivingi will be flooring it and it will not go. it flutters big time. most of the time it doesnt happen unless i go 45 - 50ish. any ideas?! and the exhaust flow is fine.
--pete
Old Sep 19, 2007 | 10:26 PM
beverlykasper's Avatar
Default RE: slugish motor. help!!!
light gets dimmer? your battery is probably due for replacement already or your alternator is not charging right.
Old Sep 20, 2007 | 5:38 AM
astroDZak's Avatar
Not enough information Pete. What year make and model? Motor size? Other symptoms?
What do you mean it goes almost silent? Is it not turning over than after a few hard turns it will spin easier?
Flooring it and it will not go right away or just after driving it for a time? What does Flutter mean?
I think what beverlykasper is thinking is you may not have enough battery to power the ignition system (spark) and be able to crank it over too.
scoogie_scott
May 27, 2022 2:58 AM
Mitchell93
Jun 10, 2013 8:23 PM
poormansdvd
Oct 3, 2010 10:58 AM
HP15
Oct 6, 2006 10:32 PM
