splicing rotted fuel lines
Old June 26th, 2015 | 9:24 AM
scottfarkus's Avatar
Default splicing rotted fuel lines
Hey guys. I've got to replace the fuel lines along the frame rail on my K1500 Suburban (1999) and was wondering if it's done just like brake lines with flare connections. This appears to be the only bad section and I don't want to buy the expensive replacement line kits. I have a flaring tool and am quite comfortable splicing out bad sections. Just appears i'll need 3/8 for supply and 5/16 for return. What do ya'll think
Old June 26th, 2015 | 7:59 PM
Richardx2's Avatar
The fuel filter has flared ends that connect to the lines you should be able to do it.
Old June 27th, 2015 | 8:32 AM
Thanks
Old June 27th, 2015 | 8:59 AM
SWHouston's Avatar
Personally, once I have a Fuel Line problem, I mistrust all of it.
I've bought proper Flexible Fuel Line of sufficient length (usually about 20) and circular clamps. Then cut the metal line just outside the tank, and at the nearest point at the engine. Routed the flex through the frame (using the additional length) avoiding areas where the metal line came close to a high heat source. Then just slipped the flex over the ends and tightened it up.
No rattles, no rust.
Old June 27th, 2015 | 12:37 PM
flexible fuel hose is a perfectly acceptable method, cheap and easy to install. the supply pressure is low and the hose can handle this pressure with no problem. buy the proper fuel system hose clamp. Some people like to put a small flare in the cut off metal line to help with retention when using hose clamps.
Another option I have been introduced to is plastic fuel hose. It is inexpensive, connects with compression fittings and will never rust or rot. If you need to introduce a special quick connect, ends are readily available at
napa. I typically only use this method for complete front to rear line replacement.
I do not use metal tubing anymore for low pressure applications; it takes to much time to install. Like brake lines; put bends in the lines, never run straight lines.
Old June 29th, 2015 | 7:45 AM
muldoon's Avatar
I used the brake line repair kit to replace deteriorating fuel lines at both ends by the fuel filter on my 1997 Suburban. Cured the problem and fuel filter was replaced several times later without problem. Still good 50,000 miles later.
RyanBlake
February 17th, 2011 6:59 AM
johnram1500
February 18th, 2010 6:21 PM
SabrToothSqrl
October 27th, 2009 8:04 AM
jffgin
September 16th, 2007 5:42 PM
jffgin
September 8th, 2007 3:23 PM
Quick Reply: splicing rotted fuel lines
