Starter...
Old Aug 4, 2010 | 10:21 PM
2wdnoob's Avatar
Default Starter...
So I know its not hard what so ever to take a starter off, but I have a 92 Silverado, and i got the bottom bolt off, but I can't get the top one off, there is pretty much no room to move around it. I need help ASAP because I'm dropping my tranny and I'm at a stand still now because of a stater.
How can i get this bolt off???
Old Aug 5, 2010 | 10:51 AM
rkuelbs's Avatar
When you say bottom and top, what do you mean? The bolts should be more "left and right". You are removing the two bolts that run vertical from the starter up into the block, right?
Usually, the transmission cooler lines and the exhaust manifold flange will interfere a little with your ratchet. But you should be able to use a long extension with a shallow socket, and carefully push the tranny cooler lines to the side. The exhaust flange may still interfere just a bit if you aren't using a wobble socket or a universal joint.
Old Aug 6, 2010 | 10:03 AM
therewolf's Avatar
Hi 2wdnoob,
Welcome to the wild world of frozen bolts. Patience and persistence are key.
You may want to support the starter and take any weight pressure off the last bolt. It may also help to run the other bolt back in, remove the stuck bolt, then remove the other bolt last.
Gently tap the starter body at the extreme end of the starter with a rubber mallet, it may help slightly reposition the starter and jog the bolt loose.
The problem with using Blaster or liquid wrench on this starter hole is you must thoroughly clean the bolt loosener out before you bolt the starter back up.(brake cleaner and Q-tips help clean up the threads) Otherwise the bolts which were such a PITA to remove during the repair may
wind up backing themselves out while you're driving sometime.
bavant
Jan 16, 2012 2:12 PM
freedomfighter_87
Dec 7, 2009 7:32 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
Gill
Jun 15, 2005 7:53 PM
