S-10 & Blazer 1982-2005
Bad starter drive? Bad Starter?
Old May 9, 2011 | 5:01 PM
bavant's Avatar
Default Bad starter drive? Bad Starter?
Hey guys, I bought a used Blazer about 9 months ago and I've been having troubles with the starter ever since. It started when I found out that the flywheel was completely bad and was grinding the teeth on itself and the starter drive. I ended up having to replace that original starter and eventually got a USED flywheel. Not only did I have to replace the flywheel but the part of the block where the flywheel mounts on was cracked and had to be re-welded. The flywheel was in pretty good condition (not sure about now), but ever since then the starter drive has been going out every few months (twice so far). I just got it replaced about 3 weeks ago, but now the starter makes a high shrill spinning sound whenever I try to crank the engine. Before it started this, and before that, it would start up fine 4 out of 5 times, but every 1/5 times, it would grind and sometimes even kick. What can I do? I really want to keep this truck but I'm lost.
Thanks in advance.
Old May 16, 2011 | 12:15 AM
bavant's Avatar
Does anyone have any idea? I really need help with this....
Old May 16, 2011 | 1:48 AM
Canadian Cowboy's Avatar
The starter motor starter drive teeth are not meshing properly with the flywheel/flex plate teeth the starter motor needs to be shimmed a starter shim goes between the engine block and the starter motor mounting pad.Below is a link on how to do it.
Starter Shimming
CC
Old May 16, 2011 | 12:55 PM
bavant's Avatar
Starter Shimming
CC
Hey, thanks a lot. I've not had an opportunity to get on this yet but once I do I'll reply the results to let everyone know whether or not this solved the problem.
Old Jan 16, 2012 | 2:12 PM
bavant's Avatar
So, the new starter that I put in the truck ended up breaking the starter after about 3 starts. This is what it looks like:
I'm trying to decide what to do to fix this truck. I'd hate to get rid of it. Any ideas?
Billy HC
Dec 10, 2018 1:59 AM
kc15
11
Mar 19, 2013 2:52 PM
Metrostar
Mar 4, 2011 9:42 AM
Jaysonic
Mar 8, 2010 9:07 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
