Starter
Old Apr 27, 2019 | 10:06 PM
scott5134's Avatar
Default Starter
I have a 76 Chevy PU K10 with a 400
I go thru a couple of starters a year. They have different issue but most get to the point that they grinding and sometimes lock. It is the same shimmed or not. I have replaced the flywheel with not change. Any ideas would be great.
I have had one housing break, one that the shaft started shifting about 1/2 inch, some that just got to the point the were grinding too much, had one that after just 3 months sounded like a car collision. All were new, no rebuilds. This has been going on for years
2 Shims
No Shims
Old Apr 27, 2019 | 10:32 PM
Irish_alley's Avatar
I'm here for the party
how are you applying the shims? have you tried just applying 1/2 a shim to the outside bolt? this will turn the starter into the flywheel
Issues with your starter? How to.
Old Apr 27, 2019 | 10:34 PM
scott5134's Avatar
I have tried one in the back to see if it would seat better, no help
Old Apr 28, 2019 | 12:39 AM
what do you mean one in the back? do you mean the outboard bolt?
did you check out the link?
Old Apr 28, 2019 | 7:29 AM
scott5134's Avatar
Outboard. It will run fine for about 3-5 months, then mess up, put in a new one then repeat
Old Apr 28, 2019 | 7:43 AM
inspect the block make sure its not cracked. have you tried replacing the bolts? maybe theyre stretched and its making the threads too loose allowing it to back out
Old Apr 28, 2019 | 11:37 AM
scott5134's Avatar
Will check, Thanks
