Steering gear shaft coupling removal trouble
Old Apr 6, 2015 | 9:04 PM
jasonthatsme's Avatar
Default Steering gear shaft coupling removal trouble
I'm trying to replace the steering gear on my 92 Chevy G20 conversion van. Having trouble getting the joint/coupling off the input shaft. I don't know what to do. There is a pinch bolt that holds it on the shaft. Pinch bolt is removed and I have spread the split open as far as I can with what I have available (screwdriver). I can get the coupling to raise off the shaft but only about half way, then it gets stuck and won't go further. Been prying on it pretty good but I don't want to use too much force and mess something up. So am I missing something? Do I need to pry the split open more? Use more force to pry it off? Any help is greatly appreciated!
Old Apr 6, 2015 | 9:36 PM
I put my medium length pry bar on the bottom of the shaft(where it sleeves over the steering gear spline) and hit the end of the pry bar with a hammer. it should move up and slide off.
put the seat belt through the steering wheel so it doesn't spin around and get put out 1 turn...you will snap the clockspring.
Cretaccir
Sep 23, 2013 2:03 PM
d.lebherz84
Oct 29, 2011 2:25 PM
DHT112A
Sep 4, 2011 9:20 PM
newfiegal_34
Sep 14, 2009 11:43 AM
rich_ncal
Nov 23, 2008 9:51 AM
