Stuck in 4 Lo
Old Jan 21, 2019 | 10:00 AM
Rednucleus's Avatar
Default Stuck in 4 Lo
Good day
05 Suburban 5.3 4x4; new transfer case in last 6 months
My wife called from Portland last night saying she was heading to her hotel stuck in 4 lo. Oh BTW happened a few days ago too. Pushes buttons and they just flash. I had her shift in to neutral and she heard a clunk and then was able to get back to 2 wheel regular drive mode. Any suggestions for when she calls me again this morning with the same problem?!
Old Jan 21, 2019 | 10:24 AM
kevinkpk's Avatar
Was the servo shift motor replaced? I'm thinking either that, or the switch.
Old Jan 21, 2019 | 11:51 AM
Rednucleus's Avatar
Don't know if the servo was changed.
How does it get itself in to 4 lo w/o pushing the button?
Old Jan 21, 2019 | 6:17 PM
kevinkpk's Avatar
Bad switch, or "feely fingers". I've had issue with both switch, and shift motor with a 2000, and a 2003. The 2000 suburban my son now has. He screwed the transfer clutch disk together with 4 bolts, I'd have done 3, 0-120-270 deg. This keeps the transfer case locked in, and selects either 2-4 wd
Old Jan 22, 2019 | 9:57 AM
Rednucleus's Avatar
"Feely Fingers"??
She made it back from Portland no further episodes. Says a couple times when she turns off car and walking away she hears a clunk or bang, like"throwing a baseball against the car". That does not sound too healthy to me!
Old Jan 22, 2019 | 3:23 PM
kevinkpk's Avatar
After you get it in 2wd, disconnect the switch.
Old Jan 27, 2019 | 10:10 AM
Rednucleus's Avatar
Mechanic found no codes, could not reproduce problem; replaced the switch.
Hopefully this is the final report!
