tach acts up as engine loses power
Old Dec 8, 2006 | 1:17 AM
brautig's Avatar
Default tach acts up as engine loses power
I got a 1993 chevy RV with 454 TBI and 4L80E trany. Once in a while on slight uphill the tach goes from a normal 2500 rpm up to 3000 rpm, but the engine rpm remains at 2500 because its in TCC lockup and it starts to lose power. If
I press on the gas the tach goes back to normal but engine continues losing power until I pull over shut off engine wait a minute restart and all OK again. All sensors and fuel pressure check OK . Seems like the PCM or ign module is getting some sort of electrical interferance. I'm stumped.
Old Dec 8, 2006 | 6:08 AM
beckeruti's Avatar
Default RE: tach acts up as engine loses power
sounds like the tcc isnt kicking out when you accelerate like it should
Old Dec 10, 2006 | 12:55 AM
brautig's Avatar
I have a switch that keeps it locked up.
Old Dec 10, 2006 | 8:40 AM
beckeruti's Avatar
is that a question or a comment
but yeah there are a few things that control the tcc
and might be aplug on the tranny to unplug and see if ur problem goes away
Old Dec 12, 2006 | 7:29 PM
brautig's Avatar
It's a complex custom switch that satisfies the PCM.
Old Dec 12, 2006 | 7:32 PM
brautig's Avatar
Could it be a sensor wire not making connection with the sensor and thereby acting like an antenna picking up stray signals? The ignition puts out some strong pulses.
Old Dec 12, 2006 | 8:01 PM
beckeruti's Avatar
maybe that complex switch has gone bad
David Bailey
Nov 1, 2013 2:32 PM
R6 Tech 413
Nov 22, 2012 5:04 PM
CHEVYOK
Nov 29, 2010 4:07 AM
byronrk
Sep 12, 2008 3:13 AM
