Technical questions about SBC build
Old Feb 3, 2021 | 2:08 PM
SBC swapper's Avatar
Default Technical questions about SBC build
I've got a '62 truck that I've been working on and while it's apart I'm going swap a 350 in for the 283 it currently has. I found a TBI 350 a few weeks ago that had all the accessories along with a TH400 trans, and I went ahead and picked it all up. The casting number on the block is 10243880, and while I haven't had it completely apart I can tell that its one of the roller blocks that wasn't fully machined for a roller setup and currently has a flat tappet cam in it. I'll be converting it to run on a carb instead of TBI, and since I need an intake I want to go ahead and get a full top end package that has heads and a cam, as well. If I'm sticking with a hydraulic flat tappet cam, can I use any cam/head/intake combo for an SBC 350 from any year, or do I need to look specifically for post-87 parts?
Old Feb 4, 2021 | 2:33 AM
oilcanhenry's Avatar
With a 1962 Chevy you would almost have to have a mechanical/cable link to the carb. You MUST determine if it is flat tappet or roller cam, before you proceed.
Old Feb 4, 2021 | 8:14 AM
It's definitely flat tappet. I pulled the intake last night to double check.
Old Feb 8, 2021 | 12:35 AM
Your casting block number matches up with a 1995-2000 GM motor.
Old Feb 8, 2021 | 9:38 AM
I came to that conclusion, as well. However, since its a bit of an in-betweener (roller block but not fully machined for roller gear), I think I'm going to sell it and try to find a true roller engine.
5.0stang
Jun 16, 2022 7:46 AM
Exec.Moose
Dec 2, 2018 4:26 PM
chevyboy1993
Aug 21, 2012 9:01 PM
92silverado
May 13, 2012 9:59 PM
