Technical Service Bulletins
Old Mar 20, 2008 | 2:30 PM
  #11
shawnvw's Avatar
Banned
Default RE: Technical Service Bulletins
#04-08-44-023C: Various Radio/CD Player Concerns (Replace Radio) - (Jul 14, 2005)
[/align]
[align=left] [/align][align=left]Subject:
Various Radio/CD Player Concerns (Replace Radio)[/align][align=left]Models:
2005 Buick Terraza[/align][align=left]2005 Chevrolet Corvette, Uplander[/align][align=left]2005 Pontiac Montana SV6[/align][align=left]2005 Saturn Relay[/align][align=left]with CD Player MP3 Radio (RPO US8) or CD Changer MP3 Radio (RPO US9)[/align][align=left]
[hr]
[/align][align=left]This bulletin is being revised to update the condition information. Please discard Corporate Bulletin Number04-08-44-023B (Section 08 -- Body and Accessories).
[hr]
[/align][align=left]Condition
Some customers may comment about one or more of the following conditions:[/align][align=left]•
No audio after ignition cycle.[/align][align=left]•
Radio presets change and audio is lost after 2-3 seconds. Refer to Corporate Bulletin Number05-08-44-019. [/align][align=left]•
Radio always returns to FM1 after CD is ejected instead of previous selected band.[/align][align=left]•
CD will not play above a certain track number.[/align][align=left]•
CD changer reads "CD Full" when it is not.[/align][align=left]•
CD eject button sticks. Refer to Corporate Bulletin Number04-08-44-022.[/align][align=left]Some of these conditions may be intermittent and reset after the ignition is cycled.
Cause
These conditions may be caused by a software anomaly in the radio.
Correction
Important:The new radio must be set up for the option configuration of the vehicle. If the radio setup is not performed, the digital radio receiver, vehicle communication interface module (VCIM), disc player and video display, and the steering wheel controls may not work properly. The radio may display a calibrate message on the display.
Replace the radio with an exchange unit. Refer to the Radio Replacement procedure in the Entertainment sub-section of Service Information (SI Document ID #1527234 - Montana SV6, Relay, Terraza, Uplander or SI Document ID #1459675 - Corvette).
Parts Information
[/align][align=left]U.S. Dealers
Radio exchange units to be obtained from an Authorized Electronic Service Center.[/align][align=left][/align][align=left]Canadian Dealers
Radio exchange units to be obtained from an authorized ACDelco Radio Centre.
Warranty Information
[/align]
Old Mar 20, 2008 | 2:33 PM
  #12
shawnvw's Avatar
Banned
The other 2Bulletins don't affect your vehicle. They have totally different radios......hope the dealer wasn't looking at this info.....
They both basically say the same thing, here's one of them
#02-08-44-020B: No Audio Out of Speakers At Times (Reprogram Radio and/or Replace Amplifier) - (Feb 27, 2003)
[/align]
[align=left] [align=left]Subject:
No Audio Out of Speakers At Times (Reprogram Radio and/or Replace Amplifier)[/align][align=left]Models:
2003 Cadillac Escalade, Escalade EXT[/align][align=left]2003 Chevrolet Avalanche, Express, Silverado, Suburban, Tahoe[/align][align=left]2003 GMC Savana, Sierra, Sierra Denali, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL[/align][align=left]2003 HUMMER H2[/align][hr]
This bulletin is being revised to clarify the models and the approved repair procedure. Please discard Corporate Bulletin Number 02-08-44-020A (Section 08 -- Body and Accessories).
[hr]
Condition
Some customers may comment that at times there is no audio out of any speakers. However, on the next key cycle the audio system may perform properly.
Cause
An anomaly within the amplifier/radio operating systems may cause this condition.
Correction
Important:Pay particular attention to this correction procedure, it is somewhat complicated. The repair varies based on the vehicle sound system. Refer to the Service Parts Identification (SPID) Label of the vehicle being repaired. The type of sound system in the vehicle will determine the repair procedure.
[ol]Determine the regular production option (RPO) code of the sound system in the vehicle from the SPID label.
Install the Tech2® to the vehicle DLC and determine the part number of the radio software and the amplifier part number.
Refer to the tables below to determine the correct repair(s). [/ol]
[ol]Silverado, Tahoe, Suburban, Avalanche, Express, Sierra (except Denali), Yukon (except Denali), Yukon XL (except Denali), Savana (with UB0, UB1 or UC6 Sound Systems without Y91 Option)
If Radio Operational software is
Radio re-programming required?
15184928, or 15184929
YES[/ol]
[ol]15100936, or 15100937
NO
Notice:BEFORE DISCONNECTING ANY AUDIO SYSTEM COMPONENT IN A VEHICLE WITH THE BOSE® AUDIO SYSTEM, THE 30AMP AMPLIFIER FUSE MUST BE REMOVED FROM THE ENGINE WIRING HARNESS JUNCTION BLOCK. Failure to remove the 30AMP fuse from the UBEC can result in a damaged Bose® amplifier.
Important:DETERMINE THE SOFTWARE NUMBER OF THE RADIO AND THE AMPLIFIER. THE RADIO MAY NEED REPROGRAMMING, OR THE AMPLIFIER MAY NEED REPLACEMENT ONLY. NOT ALL VEHICLES WILL NEED BOTH A RADIO REPROGRAMMING AND AMPLIFIER REPLACEMENT.
Yukon Denali, Yukon Denali XL, Sierra Denali, Escalade, Escalade EXT (with UQ7 Premium Sound System with Y91)
Radio Re-programming required?
If Amplifier part number is
Install new Amplifier Part Number
15184928, or 15184929,
YES
15100936, or 15100937..
No
--[/ol]
[ol]--
15054675 or 15188461
15191601
HUMMER H2 Vehicles (with UQ7 Premium Sound System)
Radio re-programing required?
15064068, or 15064070
YES
NO
15177435
15188044
Parts Information
Part Number
Description
Qty
15191601
Amplifier
(All except HUMMER H2)
15188044
Amplifier
(HUMMER H2 only)
*Do not order an amplifier for stock. A limited number of units are available at this time. Order the amplifier on an as needed basis for the repair of a specific vehicle.
Reprogramming Software
The software necessary to reprogram the radio was released on TIS version 1.5, of January 2003.
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
N4199
Module, Instrument Panel Cluster (IPC) - Reprogram
0.4hr
If the amplifier was replaced, use the published labor operation time for the vehicle repaired.[/ol][/align][/align]
Old Mar 20, 2008 | 2:44 PM
  #13
shawnvw's Avatar
Banned
Have a look at this also....the alternate frequency might be what your after....
#05-08-44-019: Radio Presets Change and Audio is Lost (Set Radio Alternate Frequency (AF) to OFF) - (Jun 23, 2005)
[/align]
Radio Presets Change and Audio is Lost (Set Radio Alternate Frequency (AF) to OFF)[/align][align=left]Models:
2005 Buick Terraza[/align][align=left]2005 Chevrolet Corvette, Uplander[/align][align=left]2005 Pontiac Montana SV6[/align][align=left]2005 Saturn Relay[/align][align=left]with CD Player MP3 Radio (RPO US8) or CD Changer MP3 Radio (RPO US9)[/align][hr]
Condition
Some customers may comment that when they recall a preset FM Radio Data System (RDS) station, the audio is lost and the station fades out for approximately 45 to 60 seconds and then returns.
Cause
Radios are manufactured with the Alternate Frequency (AF) default setting to "AF ON". When the AF function is on, and the radio station becomes weak, it will attempt to seek to another stronger station that carries the same program. This functionality has limited use in the domestic market, where individual competing radio stations do not carry the same program - unlike in export markets, where there are chains of stations all carrying the same program.
Correction
Change the radio alternate frequency to off. Review the vehicle's Owner's Manual with the customer, especially how to turn on and off the AF function. Press and hold the BAND button for two seconds. After two seconds, a beep will be heard and the radio screen will display the current AF setting (AF ON or AF OFF). If the AF setting is on, press and hold the BAND button again for two seconds. AF OFF will appear on the display.[/align][/align]
exuL1B47
Jun 6, 2014 8:42 AM
airplaneman777
Sep 6, 2012 5:49 PM
tm4hammer
Sep 30, 2009 8:25 PM
timsweet
Corvette
Aug 23, 2008 7:10 AM
kiki_v
Apr 20, 2006 1:19 AM
