TH-400 or 700R4?
i have a 67 C-20 i will be putting a 454 in, theres a 350 with a TH-400 in there now... will the 400 bolt up to the 454 and will it be able to handle the power? its going to be used for street/strip with a little towing expected, i am thinking about getting a 700R4 because of the overdrive... also what are the pros and cons of these choices?
Thanks Gary I appreciate the input, very helpful considering the most work i've done with a tranny is add fluid... ya im far from an expert with them. But im guessing the 400 will need to be beefed up a little bit, not a big deal because it needs a little work anyways. It has a bit of a leaking problem.
great advice guys i appreciate the input, i have decided to go with the 400 it will be the cheaper way to go and that will leave more funds for the 454 build up...thanks guys
