TH-400 or 700R4?
Old Aug 1, 2008 | 9:43 AM
co68956's Avatar
Default TH-400 or 700R4?
i have a 67 C-20 i will be putting a 454 in, theres a 350 with a TH-400 in there now... will the 400 bolt up to the 454 and will it be able to handle the power? its going to be used for street/strip with a little towing expected, i am thinking about getting a 700R4 because of the overdrive... also what are the pros and cons of these choices?
Old Aug 2, 2008 | 11:19 AM
co68956's Avatar
Default RE: TH-400 or 700R4?
Thanks Gary I appreciate the input, very helpful considering the most work i've done with a tranny is add fluid... ya im far from an expert with them. But im guessing the 400 will need to be beefed up a little bit, not a big deal because it needs a little work anyways. It has a bit of a leaking problem.
Old Aug 13, 2008 | 12:15 AM
therewolf's Avatar
THM400 is a tried and true GM workhorse which bolts up to most older GM V8s if you have the right tranny bellhousing and torque converter. 1Gary is right.
Old Aug 13, 2008 | 11:25 AM
old dog's Avatar
you cant beat the torbo 400 it's a work horse ,if it need' you can put output shaft seals and pan gasket's in pretty easy ,or pull it and have it refreshed at a tran's shop .
Old Aug 23, 2008 | 12:29 PM
co68956's Avatar
great advice guys i appreciate the input, i have decided to go with the 400 it will be the cheaper way to go and that will leave more funds for the 454 build up...thanks guys
Howard Pegues
Sep 9, 2013 10:48 PM
bradf92
Jun 14, 2012 1:41 PM
warlok
Dec 19, 2006 9:03 AM
warlok
Dec 8, 2006 9:09 PM
atlbigboi
Oct 18, 2006 11:48 AM
