Timing Belt
Old Sep 18, 2015 | 9:11 PM
sonimakolo's Avatar
New User
Awaiting E-mail Confirmation
Default Timing Belt
The Timing belt of my Aveo 2007 cut yesterday at 47000km. Any advice please?
Old Sep 19, 2015 | 8:46 AM
it is an interference engine so the valves and pistons may be damaged. did it occur at high engine speed?
the only way to tell is to either remove the cylinder head and inspect or put on a new belt and do compression check.
if its ok, and starts and runs, you might want to consider installing a new timing kit which includes a new belt, tensioner, idlers and water pump.
if the valves are bent, walk away from the vehicle. the expense to fix it is not worth it.
Old Sep 19, 2015 | 12:24 PM
Rednucleus's Avatar
Isn't that pretty low miles for a belt failure?
Old Sep 19, 2015 | 1:04 PM
Phillip123's Avatar
Yup. It's a little less than 30.000 miles
Old Sep 19, 2015 | 1:23 PM
it is low miles. Unfortunately quite common for Korean daiwou engines. they were junk. chevy put improved belts on them in 09 and later got rid of those crappy engines and went with the new ecotec 1.4 and 1.8.
those daiwou engines had no power and got bad fuel mileage....which is a pretty amazing accomplishment for an subcompact economy car.
landon101
22
Nov 14, 2021 10:48 AM
jmms
HHR
Apr 17, 2015 4:22 AM
OtherCarASaab
Aug 31, 2012 12:00 AM
hollijb
Feb 12, 2007 12:21 PM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
