Tire size and Computer
Old Feb 23, 2008 | 5:53 PM
FLSTFI's Avatar
Default Tire size and Computer
When going to a taller tire does it cause problems with the computer?
I know the speedo will be off but how about shift points or anything else?
If it does is there an easy fix?
This is for a 2006 3500 Express with 6L.
Thank You
Old Feb 23, 2008 | 7:59 PM
mitchell03's Avatar
Default RE: Tire size and Computer
Yes when you put taller tires on when it the spedometer gets off so do the shiftpoints you can get about any performance programmer and they can adjust these things.
Old Feb 24, 2008 | 12:51 AM
fireman526's Avatar
heres a programmer for your express: http://www.autoanything.com/performa...0A2647550.aspx
Old Feb 24, 2008 | 10:30 AM
mudmaniac's Avatar
Ride of the Month
May 2009
ORIGINAL: FLSTFI
Thank You
It has been my experience that the shift points still work fine because the shift points are based on the tail shaft rpm. You can further optimize the set up with a new program.
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
jaketruck
Aug 15, 2010 4:24 PM
Bigdawg54
Feb 19, 2009 7:24 AM
adingman99
Mar 15, 2008 9:25 AM
ice777
Uplander
Nov 23, 2006 3:15 PM
