Trans Lines
Old Apr 20, 2010 | 8:16 PM
frickenbored's Avatar
Default Trans Lines
Ok so, I'm wondering if anyone has used hydraulic hose to hook up a transmission instead of aluminum tubing. Hydraulic hose is made for oil, it can take 3000+ psi, and its WAY eaiser than bending up a bunch of aluminum tubing and trying to get it all to look good.
The hose can hidden inside the frame up to the radiator. I'm wondring if anyone has done this before and has seen problems with it?
Old Apr 20, 2010 | 8:30 PM
MDTAHOE's Avatar
Professional Mechanic
I have used rubber transmission cooler hose many times. Hydraulic hose is probably even better. I am not sure if a hose clamp could squeeze it hard enough to stay together though.
Old Apr 20, 2010 | 8:44 PM
I have these really nice gas line clamps they seem pretty stong, the ends are gonna look like this, both sides of the aluminum tubeing is flared so it seals even better in the hose:
Old Apr 20, 2010 | 8:55 PM
MDTAHOE's Avatar
I would say use it.
Old Apr 20, 2010 | 9:23 PM
Yea I'm gonna go for it, I think I'll even use some plastic electrical loom to protect the line from drit and water and hopefully extend the life of the hose. hopefully the local auto parts store sells hydraulic hose by the foot.
Old Apr 22, 2010 | 7:12 PM
therewolf's Avatar
My advice would be to use gasket tack on the outside of the flared fitting under the hose clamp, and use two hose clamps per fitting. I used an 8 " piece of fuel line for the same purpose on my van once.
The hose held fine for a couple weeks, and everything was going just dandy until the fitting and the hose came apart while I was at the front of the line, in traffic, at rush hour, in the busiest intersection in town.
Things proceeded to get ugly as I was broken down, traffic was piling up, the police arrived, and I had this massive red transmission oil puddle spreading out from the bottom of my truck...
Old Apr 22, 2010 | 8:57 PM
MDTAHOE's Avatar
The hose held fine for a couple weeks, and everything was going just dandy until the fitting and the hose came apart while I was at the front of the line, in traffic, at rush hour, in the busiest intersection :
Fuel hose will not work. The rubber is not designed to carry oil or trans fluid. The only hose that will last would be, trans cooler line, oil cooler hose, power steering return hose or hydraulic hose. Fuel injection style clamps should be used and 2 is better then one if you have the room
Old Apr 22, 2010 | 9:13 PM
therewolf's Avatar
Well, it was working fine for me, for a couple weeks, until the whole thing went "splody" at that intersection.
But you're right, MDTAHOE, I have no idea how well it would have worked over an extended period of time. It was an emergency running repair I performed after work one day to get home, when I found a worn through transmission line. I had fully intended to deal with it when I got home, but other things were clamoring for my attention.
bearbait
Feb 12, 2014 4:07 PM
Desert Silver
Mar 1, 2013 7:08 PM
rtarb41323
Apr 2, 2012 8:05 PM
jffgin
Sep 16, 2007 5:42 PM
jffgin
Sep 8, 2007 3:23 PM
