Chevrolet Malibu
2004 Malibu - howt o disconnect trans cooler lines to radiator
Old Apr 2, 2012 | 7:09 PM
rtarb41323's Avatar
Default 2004 Malibu - howt o disconnect trans cooler lines to radiator
Hello all,
For changing out transmission fluid in my car, I have already dropped the pan, cleaned the magnet, and replaced the gasket (I got approx. 8 quarts of trans fluid out of the car).
--> Regarding the fluid in the torque converter, how do I disconnect the cooler line that goes from the transmission to the radiator?
The cooler lines look something like this:
Transmission case --> steel tube --> rubber tube --> steel tube --> radiator
The steel tube joins to the radiator through, what looks like, a rubber washer, and a "thin" nut (looks kind of like a jam nut).
--> How do I disconnect the transmission line from the radiator?
Thanks for your help!
Old Apr 2, 2012 | 8:05 PM
cleveland63b's Avatar
the "rubber washer" is a cover, slide it back away from the radiator and there will be a little clip that holds the line in, just take a small pick or screwdriver and dig the clip out then pull.
usmarine0905
Nov 25, 2011 4:30 PM
zagfan1989
Sep 27, 2011 12:42 PM
Jodel
Aug 14, 2011 1:45 AM
bills 98 wt1500
May 15, 2011 10:28 PM
kevinf
Nov 16, 2008 3:32 PM
