trans not shifting into third
Old Sep 8, 2009 | 4:55 PM
roadrunner1340's Avatar
Unhappy trans not shifting into third
94 chevy 2wd 1/2 ton pu 350 auto
shifts into first and second fine but that is all wont go into third or od
Old Sep 8, 2009 | 5:01 PM
myotherchevyisablazer's Avatar
is your tranny a 4l60e?
Old Sep 8, 2009 | 5:04 PM
im told it it but im not sure how can i tell
Old Sep 8, 2009 | 5:30 PM
the letters 4L60E are cast into the side of the main case.....they might be there not super sure
Old Sep 8, 2009 | 8:10 PM
only numbers on case are a big 20 on each side and 8680514 is on the drivers side of case, lets assume it is
Old Sep 8, 2009 | 8:56 PM
when the truck shifts from 1st to 2nd what mph is the truck @
can you shift threw the gears on the coulumn when driving?
iv'e had a similar issue with one and could get it to hit 3rd when really on it,and it would shift hard...i hope your not in the same boat
Old Sep 9, 2009 | 6:16 AM
have tried to shift manually still won't shift
Old Sep 9, 2009 | 9:30 AM
therewolf's Avatar
An easy way to tell is the 4L60E has a drain plug built into the pan, stock, the 4L80E does not.
And what's the mileage of this particular truck? And the last time the transmission filter was changed?
Old Sep 9, 2009 | 11:16 AM
cams 98 silverado's Avatar
well you cant always say if it has a drain plug or not. stock mine does not have one on my trans pan. and it sounds like clutches and planetarys dont feel like engaging. according to our recent talk in trans class last friday, check for codes. because the light aint on doesnt mean there arent codes. check the condition of fluids. if its burnt, possible internal issue. check all codes though first. it could also be a failing 3-2 solenoid.
Old Sep 30, 2009 | 3:08 PM
dunhamr's Avatar
You might have a bad third gear synchronizer. The transmission needs to be overhauled if that is the case. Have you checked to see if your transmission mounts are loose. Then again you may have a bad gear linkage binding.
Merkel3594
Jan 7, 2022 10:33 PM
seeker3425
Nov 29, 2012 9:01 PM
blackwhiskeyblaze
Oct 30, 2011 5:29 PM
99chevysuburban
Apr 4, 2011 9:32 PM
scagle777
Feb 15, 2008 12:41 PM
