Transfer Case Failure due to Pump Rub
Old May 23, 2015 | 1:42 PM
Rednucleus's Avatar
Default Transfer Case Failure due to Pump Rub
This topic is discussed elsewhere and quite a bit of info on line, but until this week I had not heard of it. Best friend's '02 Yukon 4wd failed due to the "hole in transfer case from pump rub" disease. His mechanic said it's a common problem. So, my questions are:
1. Curious to hear how many of you have personally had this problem or you professional mechanics have repaired it.
2. If my '05 Suburban @ 204k mi (yikes) is ok now, should I invest in the available kit to protect future failure.
3. Is this a fairly straightforward job for the average backyard maniac to do in his garage or driveway or should I support my trusty mechanic's business.
4. BTW how often should 4x4 be engaged to keep the system happy?
Thanks for your input, Red
Old May 23, 2015 | 11:04 PM
depends on what t-case you have.
google it
for the effected t-cases:
there are several repair options. if the hole is right through:
-brny has a inexpensive repair $50 and its as easy a splitting the case
-dorman makes a case half for about 350
if the case is not damaged. split the case and install the updated pump retainer...the part is $15
Sadly, a lot of technicians don't know about the cheaper alternatives. Most order the case half from the dealer for $700 or replace the tcase. I'm going to try the brny repair for the first time this week.
Old May 24, 2015 | 9:33 AM
I only engage my 4wd when the road is slippery. its a part time system so it should not be used on dry pavement. There is no need to engage it if you don't need it.
there are a lot of video's online on splitting the t-case. if you can remove the rear driveshaft and unbolt the t-case from the transmission you should be ok. install a new t-case to trans adapter housing gasket when you put it back together.
Old May 24, 2015 | 12:34 PM
SWHouston's Avatar
There apparently are various opinions on the frequency of engaging your 4WD.
On some models, the Operators Manual suggests the frequency of that, and, how often to change the Fluid.
Many problems for hesitant shifting are due to non use. I agree that it's not needed on dry pavement, but, if one has a clear straight road to operate the system (hi/lo/hi) several times, once per month, usually keeps things stirred up well enough where when one does need it, it changes reasonably well.
I personally test my system at least twice a month.
Old May 25, 2015 | 1:52 PM
that must be for you guys with the newer torque distribution clutch pack t-cases.
jcwaters1
Oct 24, 2014 10:13 AM
Farmer Jon
Mar 8, 2014 11:19 AM
Mad Machinist
Dec 11, 2010 4:55 PM
Canamatt
Jun 5, 2008 6:29 AM
Newkie
Apr 6, 2008 12:19 PM
