Transmission Leak
Old Aug 28, 2012 | 8:40 PM
Jwald's Avatar
Default Transmission Leak
Hello All. I'm new to the group.
My '93 Chevy G20 Van with a 5.0 and automatic transmission and 136xx has developed a transmission leak. This vehichle is rarely used, and sits parked nose down on a very slight decline. It hasn't been started for a few weeks, but I noticed last night that a very recent puddle of fluid is being deposited on the driveway. A check revealed that the nose at the rear of the tranny is wet, which make me think seal. The weird part is that the drip is coming from the tranny's universal joint yoke at the driveshaft. I saw it drip and wondered why it would wick itself, uphill, to the universal. Although the nose is obviously wet, it is not dripping there. The only drip is at the universal joint. How/why would this thing start to leak after sitting idle for so long? Is the seal the only concern here? Thanks.
Old Aug 28, 2012 | 9:36 PM
there is a plug in the back of the slip yoke; if its missing trans fluid will move along the yolk splines and out to the u-joint.
Old Aug 28, 2012 | 10:02 PM
Jwald's Avatar
Thanks Tech2. I find it odd though, that this truck has been sitting for weeks, unstarted/unmoved, and suddenly developed a nasty leak just yesterday. Is the plug something that's available, or is it a yoke with plug installed purchase? Thanks.
Old Aug 30, 2012 | 9:41 PM
you would need a new yolk assembly if the plug is missing.
I don't know if thats it...just my guess from your description. Its an easy check if you know what to look for. post a pic.
Old Aug 30, 2012 | 10:41 PM
I have heard that if you clean the slip yoke real good, you can seal the hole with a good automotive silicone seal. I bought an old truck many years ago that had this done to it.
Old May 14, 2017 | 1:35 PM
Brent Fuller's Avatar
Default 95 G20. Same problem, did you ever resolve?
Just put in a new remanufactured transmission, had this same leak parked st angle. They took back and replaced transmission but just got van back and still leaking! How can I fix this?
PastorK
Mar 1, 2010 9:09 PM
brandy2277
Aug 15, 2009 8:05 AM
BMoTahoe
Oct 9, 2008 9:57 PM
OleBones
Aug 2, 2008 7:05 AM
95wt
May 30, 2008 3:07 PM
