Tune Up
Old Jul 14, 2011 | 12:48 PM
StrictlyChevy's Avatar
Default Tune Up
So I have an 07 Silverado 5.3 with 182,000 miles on it. I was wondering is there anything that needs to be serviced on it or things I should check with that much mileage on it. I change the oil and filter every 3000 miles, change the air filter and have replaced the spark plugs about 3 months ago.
Old Jul 14, 2011 | 1:30 PM
Chuzz's Avatar
How about your PCV valve? Now would also be a good time to check your serpentine belt for cracks and wear too. If those are the original plug wires, you'll want to change them too. If not, once it gets cold, you may have starting problems. Does that engine have a distributor cap and rotor button? If so, I'd change them too.
Old Jul 16, 2011 | 4:02 PM
kevinkpk's Avatar
I'd add cabin air filter to that list.
Old Jul 17, 2011 | 6:24 PM
mavmannate's Avatar
After reading the first post, those were my exact thoughts. Agreed.
Old Jul 18, 2011 | 12:16 PM
Thegnarles's Avatar
pcv valve, trans fluid, cabin filter, belts, wireset, i would use a slick 50 engine treatment, fuel injector cleaner, the list can go on...
Jeremy3040
Mar 23, 2014 7:34 PM
toymister
Apr 19, 2010 7:02 PM
nvr2fast
Jul 19, 2007 11:21 PM
jhablinski
Jun 16, 2007 2:04 PM
rynow
Jul 3, 2006 10:24 PM
