Vacuum hoses for climate control
Old Jan 11, 2025 | 4:32 PM
Swan01's Avatar
Default Vacuum hoses for climate control
2012 Chevrolet express 3500lt, 6.0L v8
Does anyone have access to Chevrolet service data? I need to know what size the vacuum hose is that goes from the vacuum reservoir ball (under battery tray) and goes to the t fitting for the climate control distribution panel.
one hose goes from intake manifold to T fitting, one hose goes from t fitting into hvac box, and the one I need goes from t fitting to vacuum ball.
any help is appreciated please and thankyou
Old Jan 12, 2025 | 11:56 AM
Take the old hoses with you to the auto parts store and get the same exact size as the old ones,
Old Jan 12, 2025 | 12:19 PM
Gumby22's Avatar
1) Intake to check valve - 1/4”
2) Check valve to reservoir - 3/16”
These aren’t the OEM sizes but they work just fine - 2 feet of each is enough. I’ve used them on several express chassis cube vans for a customer who has a fleet of them.
I also recommend replacing the check valve while you’re at it just because they’re cheap and I’ve had a few of them that broke because the plastic was brittle after several years.
3) Check valve into cabin I think is 7/64” but I’m not sure. I’ve never had to replace it. Most parts chains will have it on the shelf.
Old Jan 13, 2025 | 9:33 AM
Swan01's Avatar
thanks for the reply! Nobody at Chevy was of any help so this is very helpful info! Thanks man
Old Jan 13, 2025 | 9:35 AM
Swan01's Avatar
well I replaced it with generic fuel line hose being foolish a while ago, it keeps falling off and I already threw out the old hoses.
thanms for the reply!
Old Jan 13, 2025 | 12:26 PM
Gumby22's Avatar
You’re welcome. I forgot to mention it, but I recommend using reinforced fuel line - it stands up to the heat of the engine bay much better than regular vac or emissions grade line.
TXLeadfoot
25
Oct 19, 2025 6:04 PM
nedzad
Jun 29, 2025 1:17 AM
Crajnai
Sep 11, 2022 4:36 PM
Fred R
Jun 24, 2020 10:52 PM
MR WIZARD
Mar 15, 2018 10:08 AM
