Vibration while driving approx 40 mph
Old Jan 9, 2007 | 12:58 AM
amos221's Avatar
Default Vibration while driving approx 40 mph
I have a 2000 Chev 3500 454 cu in Dually. I have a bad vibration that feels like it is coming from the right rear of the truck. I have had all the tires balanced and rotated and still a vibration. I was told that one of the rear wheels was bent so I replaced it with a new one and had that one balanced...still a vibration. The vibration starts around 40 mph and quits around 50mph, but starts back up at 60mph. I have placed the truck on jack stands and placed the truck in gear to check to see if there was a wobble or anything.....nothing but even turning wheels.....please if anyone can help me with any ideas let me know.......
Old Jan 11, 2007 | 11:04 PM
john1967's Avatar
Default RE: Vibration while driving approx 40 mph
dont know thats crazy i cpuld not see it being much more is it winter a small chunk of ice or snow can through it off balance
Old Jan 12, 2007 | 1:54 AM
engine2's Avatar
I would road force balance the tires again. Or maybe one of the tires is out of round. Good Luck
Old Jan 13, 2007 | 1:07 AM
amos221's Avatar
Thanks John1967 and Engine2 for the posts..I need all the help I can get.....
Amos221
Old Jan 16, 2007 | 12:14 AM
midwest_guy515's Avatar
Are you sure the vibration is in the rear? I had a similiar problem that I noticed as occassional steering wheel shimmy. It was caused by a worn upper ball joint.
Even if the tires are balanced you still might get vibration or shimmy from a tire that has a bad belt. When I was troubleshooting the bad ball joint I had the shop I bought my tires from check for this during a tire rotation.They were actually the ones that told me exactly which ball joint was bad all for no charge.
Another problem could be if you have a 2 piece driveshaft. Awhile back I was reading up on a lot of problems associated with them. Might be worth the research.
Old Jan 21, 2007 | 11:04 PM
amos221's Avatar
Thanks midwest_Guy15,
I will try all ideas....and I will post what happens
Amos221
DaveW
Jul 3, 2010 5:29 PM
barbie42058
Jun 23, 2010 9:25 PM
cvpi71
Mar 8, 2009 9:09 PM
MEC407
Oct 28, 2008 6:01 PM
spike1master
Avalanche
Jun 23, 2007 5:32 PM
