Want to install 285 tires...
Old Mar 23, 2011 | 7:35 PM
Rob G's Avatar
Default Want to install 285 tires...
I want to increase to a 285/75/16 tire and currently have 265/75/16 with out doing a lift. Tire tech says it won't work on my truck.
I have 1 1/2 inch clearance between tire and fender @ it closest point. Will it work or not? Has anyone tried it yet on a similar truck?
In my garage ...I have several pix, but have not figured out how to upload pix to this post yet.
Old Mar 23, 2011 | 11:47 PM
silverbirtchz71's Avatar
is it a 4x4
Old Mar 23, 2011 | 11:49 PM
if so just crank on the torsion bar bolt until you level your truck and stick them on. there is a ton of adjustment on those trucks my 92 i had gave me almost 3 more inches for free just by turning up the torsion bars
Old Mar 24, 2011 | 12:47 PM
Rob G's Avatar
I don't know if I am comfortable in doing that. The truck is not a 4 x 4 but looks like one as it sits high already. Knowing that it can be raised higher w/o modifications...I increased the tire size.
My calculations leads me to believe that going from 265 to 285 in tire size would increase the tire tread by one inch...which leaves 1/2 inch clearance.
Am I right or is my inclinations out of balance?
pjr7269
Feb 25, 2012 4:41 AM
ogeecheehunter
Feb 28, 2011 10:33 PM
APCT91
May 12, 2010 8:04 PM
gozz
Jul 26, 2008 11:38 PM
sn75
Aug 17, 2006 1:55 AM
