water leak by goose neck
Old Jan 13, 2007 | 8:52 PM
billyboy's Avatar
Default water leak by goose neck
I have a 1999 Chevy Lumina with a V6 3.1 L.
I have replaced the Thermastat and Gasket to fix the leak. It is still leaking in the same area and I cannot seem to find the leak. I did put some stop leak in and still a leak. No water is getting in the oil.
The water leaks under no pressure.
Any sugestions PLEASE and Thank You.
Old Jan 13, 2007 | 9:10 PM
313hitman's Avatar
Default RE: water leak by goose neck
well this is a common problem with 3100's if your positive that you put your gasket in right then it might be a cracked housing. the housing material is weak and bound to break under little pressure. take it off and examine it. hope I helped...
Sparky Sparks
Dec 4, 2020 10:58 PM
usahoe18
Nov 28, 2012 8:09 AM
EllieMaysDaddy
Mar 31, 2012 2:07 PM
jsperk
Aug 15, 2011 6:25 AM
