What can reset "Engine Hours"?
Old Mar 25, 2009 | 3:08 PM
DPLarson's Avatar
Default What can reset "Engine Hours"?
I recently purchased a 2006 model year Suburban with 40+ thousand miles. The Engine Hours display showed 77 hours a few days ago. It is just above 80 now so yes, it is adding additional time properly. I don't know of a way to reset the engine hours unless swapping the engine or computer has something to do with it. Apparently GM VIS does not show ant warranty claims for my VIN.
Any ideas why such a vehicle would show only 80 engine hours?
Thanks
DPLarson
Old Apr 6, 2009 | 5:29 PM
DPLarson's Avatar
I'll answer my own question...
I found some info elsewhere that it is actually pretty common for the engine hours timer to be reset. One common way is by cranking the engine with a low battery. I'm sure this only works sometimes but I found many people claim that this reset their timer.
Old May 11, 2009 | 11:08 AM
DPLarson's Avatar
I'm reluctant to post in this thread, it's like I'm talking to myself.
Anyway, it seems that the engine hours timer can reset itself whenever it wants to. It happened recently, no low battery or hard starting engine and nothing else unusual, just noticed recently when going through the different displays that engine hours had recently been reset.
Old May 11, 2009 | 11:35 AM
EvansBlue's Avatar
Apparently, no one has experience on the matter here.
I think there were some bugs in the engine hours sytem that were not worked out before production. I have seen people report these problems occasionally.
IMO, Its a useless measurement. Everyone goes by mileage.
Old Nov 28, 2021 | 8:19 AM
Suburban Dude's Avatar
Hello. I’ll reply to this 12 year old thread. I accidentally reset my engine hours and was wondering how I did it. Looking at this thread might have explained it. I tried to crank the engine with a nearly dead battery. The engine hours reset to zero.This was a 2008 Suburban 3/4 ton.
Old Dec 12, 2021 | 11:56 AM
kiloskd's Avatar
I can reset pretty much all the other things yet not the motor hours. I realize it was reset before I got this is on the grounds that it had 54 hours on it with 6700 miles and presently I have 9800 and 189 hours.
Kodi nox
Old Dec 12, 2021 | 12:08 PM
Hi. There is a quirk that will re-set your hours. I accidently re-set mine. What you need is to put a run-down battery in place of your good one. May sure it is showing less than 11.5 volts. They try crank your engine assuming it will not start. I have seen this on on other forums and it happened to me. Mine re-set to 0 hours. Let us know if that worked.
S.D.
Hardin Thicke
Jul 29, 2010 10:46 PM
blkcloud
Sep 21, 2009 9:24 PM
92astro
Jan 4, 2009 10:05 PM
bad350trk
Mar 14, 2008 6:54 PM
