Engine Hours display means nothing!....
Old Jul 28, 2010 | 9:54 AM
Hardin Thicke's Avatar
Default Engine Hours display means nothing!....
Twice now when I've received my Tahoe back from the dealer, the Engine Hours counter has been reset to "0 hours". Both times, I've noticed it days later when I go thru the DIC readings and it's pointless to return to the dealer. Are the actual total engine hours stored somewhere where they could be recalled to the display, or are they gone forever?
Old Jul 28, 2010 | 11:58 AM
SabrToothSqrl's Avatar
Default engine hours
yea, it does seem stupid you can reset that.
If you have the scan II tool or an OBD-2 tool it should display it, I believe.
Old Jul 28, 2010 | 5:01 PM
I've been writing mine down at every fill up since day one as a way to track maintenance/servicing and well Im just plain **** like that.....
I have not seen the hours listed in my code scanner with real time data but its possible the info is stored somewhere...
Old Jul 28, 2010 | 5:27 PM
I remember hearing about this problem when the NBS first came out. Seems like it should not be resettable just like the odometer.
Old Jul 28, 2010 | 9:30 PM
LARIDERS's Avatar
I have four trip's I can reset, and when I reset a trip it will reset all info under that one. Like mpg,mph fuel used, miles, hours and so on. then there is the main one that the odometer and hours that can not be reset. sounds like we have different systems.
Old Jul 29, 2010 | 3:03 PM
Yes, the NBS DIC only resets the function showing on the display except for odometer and engine hrs. Doesn't have the Personal and Business functions like the GMT 800s did.
Old Jul 29, 2010 | 10:46 PM
LARIDERS's Avatar
I can't beleave the newer ones don't have the extra trip's. I use them all. wounder why they would do away with that?
DPLarson
Dec 12, 2021 12:08 PM
Rowdyc
Nov 28, 2013 1:12 AM
blkcloud
Sep 21, 2009 9:24 PM
tampabud
Dec 11, 2008 6:30 PM
bad350trk
Mar 14, 2008 6:54 PM
