Last edit by: IB Advertising
- Chevrolet Silverado 1999-2006: How to Do Coolant Pressure Test and Repair Radiator Leak
Step by step instructions for do-it-yourself repairs.
What is this component called on my radiator ?
Hi, my 1998 5.7 Express van has developed a coolant leak. It is leaking from what looks like a big nut on the drivers side of the rad under the top hose. It is probably some sort of blanking plug for an additional coolant hose ?
Can anybody tell me the correct name for this plug so I can try to locate a new one (that is if they are available ?).
Thankyou.
Thankyou.
I was wondering if a pressure test would show the leak - should do? If so how could I pressure test the cooling system?
I also removed the small black clips which hold the overflow hose in place and the hose from the expansion tank to the top of the rad next to the cap.
I replaced the rad cap.
I also managed to tighten up the 2 hexagonal blanks (top and bottom), they were not loose but did turn.
I no longer have a leak from the rad. I was quite surprised when going around the system to find most of the jubilee clips were not as tight as they should have been so it is worth while checking everything whenever you have the opportunity rather than when you have a problem as it could save you a lot of money/time.
The only problem I have now is coolant is leaking from what I think is the water pump, it looks to be coming from the area behind the bottom pully (is this the location of the water pump ?).
Thanks.
Hi Thanks for that info!
I am British too
so Jubilee clips is fine by me
I checked my pipework and all is fine, also pressure tested the system and found no obvious leak...
I have my leak in the same place as you mention...
I would say could be water pump or intake gasket... or both...
I am going to test drive a bit and see what happens now... But I fear I will have to go to a shop and get the intake done...
On that topic I heard that the Fel-Pro gaskets are the best for the job, is this correct?
I am British too
