Old Aug 4, 2015, 6:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
What is this component called on my radiator ?
Old Apr 5, 2010 | 2:28 PM
EnyChevyUK's Avatar
Default What is this component called on my radiator ?
Hi, my 1998 5.7 Express van has developed a coolant leak. It is leaking from what looks like a big nut on the drivers side of the rad under the top hose. It is probably some sort of blanking plug for an additional coolant hose ?
Can anybody tell me the correct name for this plug so I can try to locate a new one (that is if they are available ?).
Thankyou.
Old Apr 5, 2010 | 9:20 PM
MDTAHOE's Avatar
Professional Mechanic
That is where the oil cooler or the trans cooler connect. The only repair is to replace the radiator.
Old Apr 7, 2010 | 12:08 PM
EnyChevyUK's Avatar
Thanks, I think I'll leave it for now or try some sort of sealer, can't believe a new rad is required.
Old Jan 31, 2011 | 8:48 AM
saabman's Avatar
Hi Did you get any further with your leak?
Mine is leaking... And I can't figure out where...
Fearing the dreaded intake manifold gasket...
Old Jan 31, 2011 | 4:06 PM
therewolf's Avatar
If it's a Vortec V8, saabman, it's more than likely the waterpump mounting gaskets...
Old Feb 1, 2011 | 2:18 AM
saabman's Avatar
Hi well I am not sure... it is a Vortec V8 but the water seems to be coming from above the water pump where the lower intake manifold joins the block...
I was wondering if a pressure test would show the leak - should do? If so how could I pressure test the cooling system?
Old Feb 1, 2011 | 7:04 AM
MDTAHOE's Avatar
You need intake gaskets.
Old Feb 2, 2011 | 3:44 AM
saabman's Avatar
Yup think so...
Leaking front and back
Old Feb 2, 2011 | 2:22 PM
EnyChevyUK's Avatar
Well, I decided when carrying out a service to drain the rad, flush and replace with new coolant. This was an ideal time to go around the whole system checking and tightening anything I could see. I removed all the hoses to check for splits etc and replaced all the 'jubilee clips' (thats what we call them in England).
I also removed the small black clips which hold the overflow hose in place and the hose from the expansion tank to the top of the rad next to the cap.
I replaced the rad cap.
I also managed to tighten up the 2 hexagonal blanks (top and bottom), they were not loose but did turn.
I no longer have a leak from the rad. I was quite surprised when going around the system to find most of the jubilee clips were not as tight as they should have been so it is worth while checking everything whenever you have the opportunity rather than when you have a problem as it could save you a lot of money/time.
The only problem I have now is coolant is leaking from what I think is the water pump, it looks to be coming from the area behind the bottom pully (is this the location of the water pump ?).
Thanks.
Old Feb 3, 2011 | 3:50 AM
saabman's Avatar
Hi Thanks for that info!
I am British too so Jubilee clips is fine by me
I checked my pipework and all is fine, also pressure tested the system and found no obvious leak...
I have my leak in the same place as you mention...
I would say could be water pump or intake gasket... or both...
I am going to test drive a bit and see what happens now... But I fear I will have to go to a shop and get the intake done...
On that topic I heard that the Fel-Pro gaskets are the best for the job, is this correct?
