When is remote entry battery dieing?
How do you tell when the remote entry battery is dieing and how long do they last. It seems like when I use the remote entry lately, I have to be closer to the car and push the button a couple of times to get it to work. Is this a sign that the battery is going dead?
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> basilkies,
It may be the battery. It's also possible there may be a solder disconnect internally too. Check your owner's manual for instructions on changing the battery. If that doesn't work, contact your local dealer to order a new fob.
If you have any additional questions, please feel free to contact me.
Louis
GM Customer Service
Louis
GM Customer Service
Louis,
Charging !, I wasn't aware that was possible !
I have a 2003 Burb as you can see below, is that available on the system I have (OEM) on my Vehicle ?
And if so, just how does one go about that ?
(I don't have an original Ops Manual)
He didn't say charging the battery, he said changing the battery. You can do a Google search for key fobs and you will find many places selling them at below dealer prices. And you usually get a GM part.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> SWHouston,
Sorry, charging isn't possible with the current battery. However, it may be possible to replace it with a rechargeable one.
Since you don't have a copy of the manual, for your convenience, a digital copy is available at: http://www.extendedgmwarranty.com/ow...t-Suburban.pdf
Louis
GM Customer Service
Louis
GM Customer Service
UOOPS !
Sorry about that. Incidentally, I have an appointment with the Optometrist Friday. (so expect more mistakes till then)
in2pro, you lie !
All of you are pointing your fingers at the screen and laughing.
But, I'm laughing with you.
PS:
Louis, oldchevy, thank you for your very informative replies.
in2pro, you lie !
PS:
As long as I've gotten this Thread totally off of topic...
I enjoy going to the Range, and in recent years, have had to put a Scope on just about everything I shoot. New glasses will be TRI-focal.
PS:
Dog lovers check this one out...
Canine Lifeguard Rescues Drowning Puppy: Video - Vetstreet
PS:
mikec0777
September 13th, 2009 7:10 PM
