Where to find brake backing plates and anchor pins?
General TechGood at troubleshooting? Have a non-specific issue? Discuss general tech topics here. IF YOUR QUESTION IS SPECIFIC TO A CERTAIN MODEL, IT DOES NOT GO IN THIS SECTION.
I bought a pair of brake backing plates for a -91 Silverado 2500 a few months ago, ACDelco 14056175/14056176. They look great but I realized they came without anchor pins? Does anyone have an idea where those can be bought? Are they very generic? Haven't taken apart the car yet since it's used daily, but what I have heard so far it should be possible to remove the anchor pins from the existing plates. While that is not ideal (would prefer new/good condition ones), I suppose that is the last resort. At the same time, it seems like some anchor pins are of rivet-type (as in, can't be unscrewed)?
I've also been on the lookout for a pair of brake backing plates for a -79 Silverado C20 (yes, old enough to make it incredibly hard to find parts) for quite some time. Bought a pair that turned out to be wrong, so that was a bummer. It doesn't seem like replacements are made anymore, and naturally, it's hard to find used parts if you don't know where to look (or even what their part number is). Any help on that would be much appreciated as well!
Just to clarify, the anchor pins I'm talking about are part #4 in this picture:
anchor pins should be part of the brake hardware kit. It will include new springs which should be replaced when you replace pads.
x2
the brake backing plates are going to be one of those things that will pretty much be only found on axles already. sometimes it can be cheaper to find a donor axle rather than a specific part.
It doesn't look like the kits oldchevy linked to contain the anchor pin? I believe I've eyed over those in the past but moved on since it didn't seem to have what I'm looking for.
Here's another picture of a similar part as in the original picture I posted:
The dimension is something like 17-18 mm in diameter, so it's pretty thick.
Makes sense. Any idea where to start looking? I guess I'll try emailing a few junkyards and see if they happen to have what I'm looking for.
