Why Am I Still Over Heating?
Old Jul 26, 2017 | 8:21 AM
CJBlazer's Avatar
Default Why Am I Still Over Heating?
I have a 2002 Trail Blazer, it started over heating. I have a new ratiator, new water pump, new thermostat (yes I checked it and it works), and I've changed the gasket also a new clutch fan and it's still over heating. What else could it be? Please help!
CJ
2002 Trailblazer ltz
4d, 4.2 L
Old Jul 26, 2017 | 8:23 AM
kevinkpk's Avatar
Is the radiator still have the shroud around it? Are you sure it actually is overheating?
Old Jul 26, 2017 | 8:35 AM
CJBlazer's Avatar
A two inch piece is missing off the top and yes it's actually over heating.
Old Jul 26, 2017 | 8:41 AM
kevinkpk's Avatar
Does it overheat with the heater on, turn on heat, see if that stops it from overheating, if it does, need to look into something else. I am making an assumption coolent, level is full, etc.
Old Jul 26, 2017 | 8:43 AM
kevinkpk's Avatar
You post new radiator, it is "new"?. What pressure cap is on it?
Old Jul 26, 2017 | 9:06 AM
CJBlazer's Avatar
coolant level is full, cap is 15psi (original cap) and yes it overheats with the heat on
Old Jul 26, 2017 | 9:15 AM
CJBlazer's Avatar
Turning the he on cools it down a little but if I continued to drive it that way it would overheat. When you see I might have to look into something else what do you suggest?
Old Jul 26, 2017 | 10:29 AM
You might have to have the block flushed.
Old Jul 26, 2017 | 11:08 AM
CJBlazer's Avatar
I've done that.
Old Jul 26, 2017 | 11:33 AM
kevinkpk's Avatar
Is the radiator is new, not salvage ect.? Is it the correct radiator for the vehicle, you can get different size, ex. my lumina has a 5/8", or a 3/4" depth.
