Will a 96 caprice g80 lsd go into a 93 g20 van rear? Both 10bolt
Old Aug 13, 2017 | 12:37 PM
93G20's Avatar
Default Will a 96 caprice g80 lsd go into a 93 g20 van rear? Both 10bolt
From everything I've researched it should fit, but thought I would ask here before I go ordering gears and a rebuild kit and tearing the caprice apart.
From my research and the rpo codes the caprice should have a 30spline differential but the housing and axles are shorter than my van which uses the older Tbi Chevy truck parts. I want to swap the diff into my truck and run 3.42's. Mine are worn out and the caprice has 2.93 so towing would suck.
Thanks for any info.
My van is a 1993 g20 Beauville with a built motor, about to get the transmission from the caprice too if it's compatible. Any info on transmission differences for the 4l60e?
