Will wheels and tires fit?
Probably will, but...
Are they the same diameter (overall) ?
If not, taller tires will...
Cause an error in your speedometer (it will read slower)
Make it seem that your brakes aren't as efficient,
Seems like you don't have the power as with the other Tires,
and increases your center of gravity.
If they're wider...
They may "scrub" on your fender wells,
Produce a larger Bow Wave when wet.
The only way to really be sure they'll work, and see if you're able to deal with the changes is, try it.
If they're wider...
lcampbell
Oct 28, 2012 7:08 PM
scootr68
Jul 23, 2010 6:06 PM
I Are Hunter
Jan 25, 2010 10:54 PM
bradlasvegas
15
Mar 22, 2009 7:43 PM
