won't start when warm unless I use Starting Fuid?
I have a 94 170k 5.7 suburban that ll of a sudden is having a problem starting when it is warmed up. I can crank it over til the battery is dead and not even an inkling of a misfire or slight attempt of a fire. A shot of Starting fluid and it fires right up. What gives?? I am going to change the cap, rotor, plugs and wires as it is well overdue. Anyone thing it is as simple as that? Could it be a fuel pump (original) issue?
Any thoughts would be appreciated
Thanks
Thanks
I am in trouble now!
I did my tune up today and just for the hell of it, I had a spark tester between the coil and the Cap just to see if there was a delay in spark when turning it over. Well it sparked and started fine BUT it just stopped after a min. or so. NO spark what so ever now. I tested the ign. fuse and there is constant power when turning it over. What do I check now? I tested the black and gray spouts on the coil but there was no power there if that means anything. I am at a loss in trouble shooting this. All ignition parts other than the cap rotor wires and plugs are original. Remeber, I have 172k on this truck.
Any help please!!!!!!!!!!
solved
problem solved! Replacing my igniton module, which tested ok by Autozone, did the trick! Started right up. Just would of liked to see some input from this forum. Very disapointed.
The forum takes time 94...ya gotta be patient (and it's not nice to disparage the people here[that's "dis" for you younger folks]). Your problem was complex and could have been any number of things and yet you did finally find the answer didn't you? So lighten up please.
advcomps
September 18th, 2013 11:22 AM
gdavies07
November 8th, 2011 12:47 AM
Scootertrash
14
July 26th, 2009 11:32 PM
bibilulu
January 26th, 2008 12:09 AM
