HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
2007 HHR trouble starting
Old Nov 21, 2021 | 11:46 AM
Arch.gloria12's Avatar
Default 2007 HHR trouble starting
So I have a 2007 HHR. No check engine light. No codes pulling up on computer (autozone’s). I wish I could describe the sound thoroughly but for that I’d rather post a video (which I can’t…?). Best I can say is that it isn’t clicking. Just “normal” sounds right before a full engine crank. It just doesn’t crank from time to time. And sometimes when it does it sounds very sluggish for a few seconds before it achieves normal rpms and idling.
As I mentioned, no codes being shown. All fuses were checked and good. I put in new spark plugs. Coil packages. And a new starter. Engine is getting gasoline. Still haven’t fixed this issue.
help?!
Old Apr 5, 2022 | 9:02 AM
HHR guru's Avatar
help?!
have you bled your fuel rail? Also, replace camshaft sensor near the top of your engine. You can look at the part by Google or you tube. It may help you
Bpopilek
HHR
Apr 20, 2018 9:57 PM
savgmc7
Feb 21, 2017 1:08 PM
dgrossjrd
HHR
Feb 13, 2015 9:09 AM
BrettSt
Sep 13, 2014 5:12 PM
rrs57
Sep 19, 2010 11:58 PM
