HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
Locked up brakes
Old Feb 14, 2023 | 10:54 AM
ohskmcdowell's Avatar
Default Locked up brakes
Help! I have a 2007 hhr that I love. No rust no issues, except one. All 4 breaks lock up. They release after about 45 min. You go no where when this happens! I have had it to 3 “back yard” mechanics. We have replaced Everything brake related. ABS module, pump, break lines, breaks etc etc etc! Nothing has helped. This is my last hood before taking it to a Chevy garage and paying out the you know what! This problem all started after replacing the Master Cylinder. You think wow we finally fixed it! But after driving for about 45 min, you’re stuck. What could be the problem?
Old Feb 14, 2023 | 1:54 PM
wrong master or issues with the master cylinder push rod length. if the rod does not have enough free play it blocks the ports in the master so fluid can't return properly. as the fluid get hot it applies the brakes more.
check the brake pedal free play
Old Feb 14, 2023 | 6:10 PM
[QUOTE=tech2;487529]wrong master or issues with the master cylinder push rod length. if the rod does not have enough free play it blocks the ports in the master so fluid can't return properly. as the fluid get hot it applies the brakes more.
check the brake pedal free play[/QUOTE
This is the 3rd Master Cylinder we've put on it. There's no place to adjust the push rod length. I had thought the same thing about the length. But nowhere to adjust. I'll check the free play
Trailblazer Sucker
Apr 29, 2022 6:55 PM
Trailblazer Sucker
Apr 26, 2022 4:12 PM
dukem60
1988 - 1998 (GMT400)
May 16, 2019 1:51 PM
Burtle
Oct 8, 2016 7:15 AM
halfasemitone
Dec 2, 2009 10:39 PM
