HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
My 2008 hhr cool fan!
Old Jun 15, 2018 | 4:50 PM
Cody McCaslin's Avatar
Default My 2008 hhr cool fan!
Hello all my 08 hhr cool fan fuse 30A keeps blowing I know it has to be a short but I'm having a hard time finding it. Any advice???
Old Jun 15, 2018 | 7:53 PM
turbo or na? how many wires to the fan motor?
inspect the cooling fan motor...does it spin freely?
Old Jun 15, 2018 | 8:02 PM
Its na turbo and there is 2 wire with connectors, and fan spins with a little lag to it.
Old Jun 15, 2018 | 8:20 PM
which..na=normally aspirated or turbo...can't be both. they use different systems...charge air cooler.
Old Jun 15, 2018 | 8:29 PM
It is not a turbo. The fuse will work for maybe a hour or 2 and I have to replace the fuse.
Old Aug 10, 2022 | 3:23 PM
HHR guru's Avatar
Default Cooling fan short
I would recommend running a new circuit through your fusebox and abandon the old circuit.it may take some time, but a short in a particular circuit is difficult to run down. There are slots labeled as empty on your box.use new wires or you'll have the same problem
you may also have a bad fan motor drawing too many amps
Old Aug 10, 2022 | 3:27 PM
HHR guru's Avatar
fan should spin freely, no dragging. Even the slightest drag can indicate failure
mikeshaw
Jun 27, 2019 2:10 PM
Kenneth Allan Corder
Aug 12, 2017 12:04 PM
Kooshball1500
Apr 2, 2016 9:28 PM
htopball
May 6, 2010 6:00 PM
nashfad
Feb 5, 2007 2:54 AM
