HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
Overheating
Old May 28, 2022 | 11:50 AM
Dawn Canter's Avatar
Default Overheating
My 2006 HHR is overheating. Replaced radiator cap, thermostat, water pump, mass airflow sensor. Also replaced head when it was checked and there was a crack. Flushed out radiator replaced coolant. Replaced head gaskets, radiator but its still running hot!!!
Old May 29, 2022 | 10:04 AM
kevinkpk's Avatar
Did you get the air out of the system?
Old Jun 4, 2022 | 3:48 AM
HHR guru's Avatar
[QUOTE=Dawn Canter;479187]My 2006 HHR is overheating. Replaced radiator cap, thermostat, water pump, mass airflow sensor. Also replaced head when it was checked and there was a crack. Flushed out radiator replaced coolant. Replaced head gaskets, radiator but its still running hot...hello have you checked the cooling fan relay? If you continuously have to add water,check your head gasket again. If you had replaced the head, it may be out of time.it has to be exact. Do you get misfires?? You may also have the incorrect heat range on your spark plugs.im just shooting ideas.correct oil??let me do some research and we'll see later
Old May 22, 2023 | 12:54 AM
HHR guru's Avatar
Default Overheating
[QUOTE=HHR guru;479378]
okay if you checked all this,including the thermostat,as it may be stuck.the clogged heater core could also be the cause.have you checked engine timing?hhrs do not overheat easily. They are very particular,will last forever if done right
Dawn Canter
HHR
May 28, 2022 11:51 AM
dlblansett
Sep 13, 2017 1:27 PM
Tabitha Gullett Louden
Aug 24, 2017 3:45 PM
jsepps
Mar 29, 2014 5:44 PM
MontePythonCarlo
Nov 28, 2009 4:51 PM
