HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
Put new Clutch in now car will not run
Old Nov 5, 2023 | 5:01 PM
11111111's Avatar
Default Put new Clutch in now car will not run
car 06 HHR should have 2.2 will manual transmission, put clutch in car and will not start
Car ran fine wouldn't move before work done, not my first rodeo but too many clowns in arena , angry clowns
Looking at wiring diagram for 06 HHR with 2.2 cam and crank sensors are not in same place as diagram , engine was changed don't know what i have
Only 2 plugs above starter and no plug in place for cam sensor going by 2.2 diagram
Car is a rust bucket, engine ran fine with low miles,
have checked
Fuse under hood good
And following wires by diagram for 06 2.2 HHR this engine must not be same no cam or crank sensors
Fuel pump working, can hear it and smell gas when holding to floor and turning key
Not getting fire? Can't locate cam or crank sensors don't know how many sensors would stop engine from starting
Crushed a plug on transmission, can be seen under hood at rear of transmission, replaced plug and may have crossed wires, color of wires on new plug different, switched wires anyway and nothing changed
Started checking all of the wires by diagram and don't know what engine i have or what's been changed , don't think it is 06 HHR 2.2
Don't know what sensors work together allowing coils to fire or how/what to bypass to get fire
Know clutch sensor working, car will not turn over without pushing it
Everything is plugged in
Have check engine light on, cheap reader says no codes
Before working on only had evap code for gas cap , cleaned cap no code
What is engine if not 2.2 ?
Old Nov 6, 2023 | 8:35 AM
does it crank over no start or no crank?
Nox
Jun 3, 2022 4:19 PM
Covah161
Oct 3, 2019 3:02 PM
ZandarKoad
Feb 28, 2011 8:52 AM
maxxman04
Feb 3, 2010 10:56 AM
GeneKam
Jul 25, 2008 2:33 PM
