HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
Steering wheel locked and ignition won't turn
Old Apr 8, 2017 | 11:17 AM
umwolverines's Avatar
Default Steering wheel locked and ignition won't turn
I was going to change the headlight on my sister's 2007 HHR and since you have to remove the plastic wheel well liner I thought I would turn the wheel in to get some more room. But like a dummy I turned the wheel with it off thinking I can move it like on my 2003 Silverado, but now the wheel is locked and the ignition switch is pushed in! What can I do?
Old Apr 8, 2017 | 3:12 PM
Gravydog316's Avatar
any luck?
usually you just have to keep playing with steering wheel & it will unstick
Old Apr 8, 2017 | 6:13 PM
turn the steering wheel and hold it...to put some tension on the steering lock linkage...with tension on the wheel....you should be able to turn the key. try both directions
