2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
00 Impala Coolant Questions
Old Nov 4, 2007 | 11:05 PM
Twim's Avatar
Default 00 Impala Coolant Questions
Hi,
My father put in about a gallon green coolant in the fill tank, is this going to be a problem?
Why did the car need so much coolant without any visable signs of a leak?
Thanx in advance!
Old Nov 8, 2007 | 6:41 PM
Twim's Avatar
Default RE: 00 Impala Coolant Questions
I can really use some help on this.
Old Nov 9, 2007 | 7:00 AM
jla74's Avatar
It is pretty common to have intake manifold gaskets starting to leak on these. I would take a real close look and you might find some spots around the manifold where it has been leaking and burning off. Try to see how much time it is between top-offs to determine how bad the leak is. Does it have the 3.4L engine?
Old Nov 9, 2007 | 9:31 AM
Twim's Avatar
Sorry, it is 3.8.
Is there a kit I can purchase to make the repair?
Old Aug 11, 2008 | 9:53 AM
cfrank's Avatar
ORIGINAL: Twim
Hi,
Thanx in advance!
I am sure that your 2000 impala uses the orange dexcool and i noticed you said that green was put in the recovery tank? The two coolants are NOT COMPATIBLE!!!!! that can cause lots of damage, when the two diffirent types of coolant come in contact with each other they form a thick rust/brown colored mud that will block up water jackets,coolant lines,and thermostats. Also this will start to corrode internal parts of the engine. Take it to a mechanic and get your engine coolant drained out immedialtey and have it flushed a few times.
Old Aug 11, 2008 | 3:10 PM
rbarrios's Avatar
I agree.... get the gasket fixed (most likely culprit)....
and flush the engine... the red and green antifreeze do not MIX....
being a 2000.... you were way overdue for a dexcool coolant change... it has a life of 5 yrs or 150,000 miles...
dlaroche
Oct 29, 2014 7:17 PM
BenAyres14
Jul 19, 2012 1:54 PM
mcstein
Apr 19, 2012 11:08 AM
erik2282
Aug 15, 2009 4:45 PM
crewguy
Jun 21, 2007 5:21 PM
