01 3.4L Impala hesitation/accel problems
Hi all! Tried searching but didn't find any good answers (probably input the keywords wrong...sorry!).
2001 Impala 3.4L w/145k miles.
Started hesitating and 'laboring' on acceleration, especially when starting from a stop - 30mph. Then again about 50-60 mph.
Motor runs fine through low-high RPMs when in park.
Trans appears to shift just fine, like it always did. Haven't yet checked engine code at O'Reilly but will do so this week.
Thought it might be plugs/wires as they had never been done as far as I know. Plugs wires now replaced, problem still exists.
Search did point to a few candidates (air sensor, etc.) and hopefully there's a code to help me. Check Engine light does not come on. Hoping it's a DIY or low cost fix of course. Any other possible easy suggestions requested.
Thanks!
Thanks!
Okay. Replaced plugs/wires with no change. Still no check engine light either.
Next candidate was the fuel filter. It was orginal as far as I know, maint guide says it should be replaced every 60k miles or so. So replaced that fairly easily...no change.
Began to think I was victim of the known Catalytic Converter plugged up issue, but of course I am 6 months past the 10 yr limit and 45k over the 120k mileage limit.
It did finally throw a check engine code (PO404), was expecting PO420. PO404 appears to be the EGR (stuck open apparently). So, will buy me some carb cleaner and have a go first at cleaning the EGR.
How to Change the EGR Valve on a Chevy Impala | eHow.com
If that fixes it, I'll take back the Cat I just bought for a refund at O'Rielly. If that doesn't fix it I'll report back with an update.....
So, will do a search on this, but in the process of removing my EGR valve I disconnected the air-intake side of the breather tube only to later noticing the other end was disconnected too.
Not sure where it attaches, hopefully it will be obvious but if anyone can point me what to look near that would be great!
Thanks!
Thanks!
After attempting to clean the ERG valve with no change. TOok it too local shop. "Think" it's the cat converter that they'll swap for me for $490.
Part plus gasket that I already bought were $198.00.
Youtube vids make it look pretty straight forward. I need to call back to a 2nd shop who I think initially quoted me $325.00. Reputable shop that co-workers trust.
I have access to fully stock auto shop with lifts, tools and on site master mechanics who are there to give advice on base.
So, what to do. $500 sounds high. I was leaning towards paying the $375 to have someone who knows what they're doing just do it. Otherwise I am sure in a day I can DIY for $20 for use of the shop.
Thoughts? Opinions?
Thanks!
Thoughts? Opinions?
Thanks!
eightmin
Apr 11, 2017 8:23 AM
beaverton007
Nov 14, 2005 11:20 PM
