06 Impala Criuse Control engages uncommanded.
My 06 Impala has steering wheel controls for radio & cruise control. It has begun to act up recently. The cruise control has engaged uncommanded & the radio has changed stations uncommanded. Any ideas?
Just to verify that it is what I think it is, remove the airbag, and d\c the steering wheel controls. See if the problem goes away. If it does, then you need some new controls.
Also might want to make sure that your aren't inadvertantly pressing the button while driving
To remove the air bag, insert a small blunt-ended tool (I usually use an allen wrench) through the access openings, on the left and right of the steering wheel, push on the blunt-ended tool to release the steering wheel inflator from the steering wheel.
By engage, do you mean turn-on or do you mean turn on suddenly and go say from 40 to 80 real quick? Cause if it's the latter, pull the fuse and get that damned thing fixed! Please!
The CC simply engages to maintain speed. It has done this twice. The first time, I thought I must have engaged it. The second time was in rush hour traffic & I never use it in RH. I'm certain it engaged by itself. The horn has honked 3 quick times just after I shut off the car. The radio has changed channels twice by going to the next programmed channel down. All three of these systems have controls on the steering wheel which are capable of commanding these 3 symptoms. This is quite a coincidence. I called 2 GM parts departments & they say they don't have calls for SIR Coils (clocksprings). I talked to a repairman who said look for a short behind the airbag. Believe me, if the car began to accelerate on its own, I'd have pulled the fuse.
richinalbany
May 25th, 2014 6:27 AM
barrylito
September 26th, 2009 6:56 PM
