2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
1967 Impala 283 running REALLY rough
Old Oct 15, 2012 | 6:04 PM
oldyellowchevy's Avatar
Default 1967 Impala 283 running REALLY rough
A little wisdom is appreciated... My '67 Impala Convertable is running really rough. It has 116k original miles and never rebuilt... Replaced plugs, wires, dist cap, carb. Not sure if it is timing, compression or a valve thing at this point. No backfires, and the fuel pump works fine. Any thoughts are appreciated. Thanks!
Old Oct 15, 2012 | 6:47 PM
kevinkpk's Avatar
So, this problem started before you replaced these things, and no change? Did you replace the points?
Old Oct 15, 2012 | 9:33 PM
Gwampa's Avatar
Might check the wire from the coil to the distributor too. They tended to get kinks and loose contact at the entry to the distributor.
65Mike
Jul 6, 2014 6:00 PM
65Mike
Chevelle & El Camino
Jul 6, 2014 5:42 AM
89silverado283
Apr 6, 2009 2:46 PM
89silverado283
Apr 4, 2009 6:16 PM
porshapower
Aug 21, 2008 2:14 AM
