1985 impala unknown wire..
hello, i was working on my car today and looking above the starter on the passenger side was a wire and a plug that is unhooked. i have no idea what its for so i thought you guys could help me out.
im new to this forum and cars so please bear with me
the wire comes from a big wire loom on the passenger side right next to the hood spring, it dangles down almost level with the frame and the female part looks like those pull and push caps on water bottles but has a little gasket around the base
Must not be too important if the car runs without it being connected. Could be from something that is no longer used such an accessory installed by someone else and then removed.Can't really tell from picture if it is electrical wire or a hose of some kind.
The speedo works fine but the oil pressure sending unit is disconnected
So the oil light is on but other than that all the gauges work.
Where the wire meets up with the male part looks like a single standard copper wire just like the electric choke wire....if that helps any
