2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2000 Impala LS Starting problems
Old Aug 5, 2013 | 2:53 PM
-DB-'s Avatar
Default 2000 Impala LS Starting problems
I have a 2000 Impala LS, and a few days ago it wont start. But i tried again a day later and it started but it was making a sputtering noise like there was no gas, or no gas was coming through. But there is gas in the tank. I decided to change the fuel pump, but that wasnt the problem, and i also changed the gas filter, and that wasnt a problem. I dont know what else to do, Has anyone ever had this problem, and does anyone have any suggestions?
Old Aug 26, 2013 | 11:14 PM
go-part's Avatar
Former Sponsor
Does the car stay running if you have your foot on the gas pedal?
Old Aug 27, 2013 | 5:39 AM
GilbertF's Avatar
What I would do first is check your battery cables, the cables to your starter, and so on. Make sure they are all tight. If you can twist them or move them they are too loose. Also check for corrosion, excessive build up can cause the electricity not to be able to conduct well enough to turn the starter.
Also just a side note, when you stick the key in and you can't turn it, try moving your steering wheel back and forth while you are putting just a little bit of pressure on it, they have locks on them, and if there is a strain on the steering wheel you will not be able to turn the key, and this becomes more and more common each year a car gets older.
If all your cables are tight and clean, and your battery is charged but the problem persists the best thing to do would just be to take it to someone else to look at.
brentandbecky
Jul 21, 2016 3:41 PM
came doc
Site Feedback
Sep 28, 2014 6:18 PM
GrayHeadedMule
Jul 11, 2013 4:52 PM
pen63
Jul 8, 2011 12:54 PM
shaft24
Nov 27, 2007 1:15 PM
