2000 LS (Transmission code)?
I registered to ask a transmission question for my fathers Impala.
We need to know what the transmission code is.
It needs to be replaced.
Upon searching I found the code : 4T65-E
But the mechanic tells him that he needs a LNB or LNN number of some sort.
I am guessing that this has to do with the gear ratio's.
Could you guide me toward my answer?
Thanks in Advance.
Thanks in Advance.
Impala Super Moderator
RE: 2000 LS (Transmission code)?
A.T., 3.8L, 3.29 ratio FR9, ident LCB
A.T., 3.8L, 3.29 ratio FR9, ident LNB[/b]
A.T., 3.4L, ident RLB
A.T., 3.8L, 3.05 ratio F83, ident LPB
A.T., 3.4L, ident RDB
A.T., 3.8L, 3.05 ratio F83, ident LBB
tHOSE ARE ALL THE TRANNY OPTIONS FOR THE (damn caps) 00' impala. tell me which one you have and I will tell you what it fits. I am sure any of them can be made to work with modifications to lines, PCM and whatever else. Ask a trans guru to travel that road.
you can also contact GTPED@msn.comfor your answer
Ok. Thanks so much for your response.
All I know is that it is a 2000 Impala with the 3.8L V6 motor and Automatic Transmission.
It will have one of these:
The thing is. I have no idea which one.
He both scavered over the engine bay and under the transmission looking for the code, but we could not find one.
Is it stamped somewhere on the transmission?
We just need the right code so our mechanic can pick up the right transmission to do a direct swap.
On my Honda Prelude, the transmission code is stamped right next to the block code.
Will it be similar on the impala?
He cannot find either of the codes on the Impala.
ORIGINAL: HotSauce6226
I dont see y he needs that, there are 2 4t65e trannys...4t65e and a 4t65e hd
You have been geat help
I will let him know that those dont matter and all we need is a 4t65e transmission.
No problem at all, ask anything you want. As far as know that doesnt matter. I could be wrong but with what i know all you need is a 4t65e tranny.
Are you getting a rebuild? I would highly suggest you ask the company if they are doing a Sonnax Sure Cure Kit on your tranny. It fixes alot of the factory flaws in the 4t65e. Let me knwo what they say
I believe the SPID label is in the trunk for your car, it will have the tranny code labeled there along with all the codes for your car.
You could also post your VIN and I'll do a quick search and find out the codes for you
<table style="border-collapse: collapse; width: 48pt;" width="64" border="0" cellpadding="0" cellspacing="0"><col style="width: 48pt;" width="64"><tbody><tr style="height: 15pt;" height="20"> <td style="height: 15pt; width: 48pt;" width="64" height="20">I have the Magnaflow too and love it, my brother got his used from craigslist but I wanted a valid warranty so I got it here. Magnaflow Exhaust 15713, or you can try one of the sponsors here on the forum, they are allways having sales/specials. Either way its a great exhaust system, sounds great, and very easy to install.</td> </tr></tbody></table>
New User
Awaiting E-mail Confirmation
could somebody help me, I have an Impala 2000 with 3400 engine, I replaced my transmission without knowledge that there are several transmissions available for Impalas, now my replaced transmission is failing again and I need to replace it for a new one but I need to replece it for the right one.
can somebody tell me how can I know which tranny number is the right for my Impala.
TMcWeed
July 5th, 2015 10:05 AM
Vinna
November 12th, 2012 8:51 AM
