2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2002 Impala AC Problems
Old Apr 25, 2011 | 10:06 AM
jbizub5192's Avatar
Default 2002 Impala AC Problems
Hi everyone, Last year I had to recharge the ac system because the system was low. I had to charge it again now because it low, Its only a small leak so I could put up with recharging it. The problem I have now is after I pulled a vacume on the system and then recharged it I still have no ac! But I did notice that the small ac line going into the firewall ices right up in about 30 seconds as soon as you turn the ac on. What could be causing the line to ice up which im pretty sure is the reason why I have no cold air. The compressor kicks right on like its supposed to but I get no cold air lol.
Thanks for the help!
Old Apr 26, 2011 | 10:03 PM
jbizub5192's Avatar
Any Ideas lol? Thanks
Old May 12, 2011 | 10:02 PM
jbizub5192's Avatar
Does anyone have a idea what could be causing this?
Old May 16, 2011 | 11:00 PM
jbizub5192's Avatar
I cant believe know one was any ideas?
Old May 17, 2011 | 4:03 PM
Gwampa's Avatar
Patience is a virtue......someone will answer, just gotta give 'em time.
Old May 19, 2011 | 8:48 PM
jbizub5192's Avatar
Sorry im just used to all of the other forums i belong two and they usually respond within a hour
Old May 31, 2011 | 11:53 PM
jbizub5192's Avatar
Still no ideas?
Old Jun 1, 2011 | 8:20 AM
Did you replace the accumulator? its possible the accumulator has become clogged and not allowing the freon to flow properly...
Old Jun 1, 2011 | 8:41 PM
klutz1's Avatar
Freezing is caused by a rapid decline of high to low pressure pressure. The exact way it cools. Possible the leak has grown. Do you have gauges?
Old Jun 2, 2011 | 9:27 AM
jbizub5192's Avatar
Thanks for the response! I did not replace the accumulator and didn't check that. Where is that located? By the firewall? I do have a set of gauges and If I remember correctly it was around 150 on the high side. I forgot the low pressure. What should the pressure be? Thanks again!
brentandbecky
Jul 21, 2016 3:41 PM
pen63
Jul 8, 2011 12:54 PM
bwgood
Apr 27, 2007 12:28 PM
