2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2003 Chevrolet Impala Base (3.4L V6) -- Error Codes B0100 & B1000
Old Apr 23, 2010 | 10:09 AM
shadyjewmobster's Avatar
Exclamation 2003 Chevrolet Impala Base (3.4L V6) -- Error Codes B0100 & B1000
I have a 2003 Impala with the 3.4L V6. My airbag light is on and when scanned, Error Codes B0100 & B1000 are returned. B0100 comes back as an ELECTRONIC FRONT END SENSOR and B1000 comes back as an ECU MALFUNCTION. Can anyone provide some insight into how to repair these two codes? Please help.....
Old Apr 23, 2010 | 12:37 PM
HotSauce6226's Avatar
Impala Super Moderator
Replace your ECM and go from there
Old Apr 23, 2010 | 12:48 PM
that seems like an incredibly unnecessary and expensive fix for an idiot light and two error codes. isn't there a part that might need to be replaced? maybe a sensor?
Old Apr 23, 2010 | 2:49 PM
Its your car. Do as you wish. Go get the codes cleared and see if they come up. From GM service tech:
DTC B1000
Circuit Description
Each control module runs a program to detect internal memory faults. No external circuits are involved. If a control module detects any type of internal memory fault, that control module may set DTC B1000.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC B1000 Electronic Control Unit (ECU) Performance
Conditions for Running the DTC
*The control module has power and ground.
*The ignition is ON.
Conditions for Setting the DTC
DTC B1000 will set if either of the following conditions occur:
*The control module detects an internal write malfunction.
*The control module detects an internal checksum malfunction.
Action Taken When the DTC Sets
Any of the following actions may occur:
The control module refuses all additional inputs.
*The control module requests the malfunction indicator lamp (MIL).
*The check gages chime sounds.
Conditions for Clearing the DTC
*A current DTC clears when the ignition is cycled, and the malfunction is no longer present.
*A history DTC clears when the ignition is cycled 100 times without a repeat of the malfunction.
Diagnostic Aids
*DTC B1000 may be stored as a history DTC without affecting the operation of the module. If stored only as a history DTC and not retrieved as a current DTC, do not replace the module.
*If DTC B1000 is retrieved as both a current and history DTC, replace the module that set the DTC.
Old Apr 23, 2010 | 2:51 PM
Also there is a TSB on this.
Alil google search will find this:
http://74.125.93.132/search?q=cache:...&ct=clnk&gl=us
Old Apr 23, 2010 | 2:52 PM
see now i get it. i thought u were just saying that to mess w me lol. thank u for the info. we cleared the codes and only B0100 came back. B1000 went away. we're gonna do an ohm test on the wires to the sensor first and if they're ok, we'll replace the sensor. if that doesn't worked, well then i dunno what to do. if anyone else has any idea, please don't hesitate to tell me.
Old Apr 23, 2010 | 2:54 PM
hey hot sauce, which tsb is for this one. i didn't see an airbag one or a B0100 one. ur help is beyond appreciated now bro. ur awesome!
Old Apr 23, 2010 | 2:55 PM
When people are having problems with cars, its not time to mess with them. Even after clearing them, they might come back. Just keep an eye on it.
Old Apr 23, 2010 | 2:58 PM
will do sir. and i will of course post if my fix corrects the problem. and if not, whatever fixes the problem will be posted. thanks again for ur help dude.
Jacking
Dec 5, 2014 9:14 AM
UofMfanJJ
Nov 29, 2014 6:33 PM
2010_CGs_CarandBikeShow
Sep 30, 2010 3:56 PM
ericksob
Jun 6, 2007 1:27 PM
J2FcM
Jul 6, 2006 3:53 PM
